The roof could be wrapped or painted. The sun damage to the polymer roof is done at this point.
I was really hoping not to hear thisThe roof could be wrapped or painted. The sun damage to the polymer roof is done at this point.
Nothing to lose... nice!...I will try a jitterbug type sander and some 400 or 600 sand paper to begin with and work my way up to 800-1200-1500-2000 grit sand paper and plenty of water...and finish it off with some plastic cleaner/ polisher...
Jetfuel....nothing to loose...
My 2009 Passion has some of the same deterioration, but not as bad as the above photo. Mine is mostly confined to the rear 8" of the roof. It looks like a thin top layer has been peeling away. I tried some plastic polish but it had little effect. I have the crazing as well.If you want a clear roof, then your choices are to try and refinish it, which probably won't give you a crystal clear roof , or replace it. If you just want it to look good and don't care about being able to see through it, wrap it. I redid the wrap on my pure (with the solid roof) and it turned out great. I even used a carbon fiber finish and it glistened in the sunshine!
Not too sure painting it will hold up too well on a roof with that much oxidation.
Hello my fellow Smartiez!
I own a 2009 Passion and the hard top has plenty of oxidation. California sun is hard on cars and also, my bad for letting it go this longI've attached a photo for better understanding of what it's become. Can anyone tell me what method would be best of getting rid of the oxidation. Hopefully a good of the shelf product and pad will do the job. If I am able to remove the oxidation, how can I protect it so this doesn't happen again. Any advice is appreciated!![]()
Thank you!![]()
