Anyone else ever have this code? "ECM internal engine-off timer "
Apparently this tells the ECU how long the engine has been since it's last been run. Why this matters is beyond me and I used to have 5 ASE cert's in my youth. From what I gather this is likely some fault of the ECU not getting proper voltage from the battery (I'm guessing the shop that installed my sound system messed something up here) and the ECU can't tell how long the engine has been shut off. This is probably also why my radio head unit displays 12:00 every time I start the car.
The interesting thing is that this error code manifests itself by causing EVAP system issues like the other 2 codes I was having. I'm a little confused though because I had the evap leak code for weeks before the radio was installed.
Either way it's going to a shop this week to get sorted out. This morning had a hard start, almost cut off for several seconds until it warmed up a bit. Not good signs for a car with only 8k miles on it.
