1 - 3 of 3 Posts
So. I recently purchased a Smart from a Kia dealership less than a month ago. This is my first smart. Everything was going great until I noticed the Tire pressure light comes on consistently and now I'm getting a check engine light. I called the dealership and they told me it was sold as is. It's a 2009 Smart ForTwo Passion and some research showed this was the culprit.
https://www.partsgeek.com/catalog/2009/smart/fortwo/air_intake/electric_change_over_valve.html
My question is, if this is the culprit. Mine only has two hoses attatched, is this normal or no? If so should I swap this out for a new one? I used my OBD scanner to read the code and It spit out a p2440. The part seems easy to swap even for a novice like me. I removed a battery terminal to reset the CEL and I'll see if it comes back.
1 - 3 of 3 Posts
