im looking for several parts....
1) side marker lights...both sides (the little ones on side of front fender)
2) rubber cover on back of headlight housing ( covers the bulb replacement area)
3) lower rear shock cover passenger side ( this covers the lower rear shock bolt)
I found the side marker lights on EBay.
Also if you need the little washer that holds the side marker lamp in place, I found those in the plumbing dept. (rubber O-rings) at Home Depot.
I have the light rubber cover/cup. It's about 3" in diameter. I'm not sure what you mean about the lower shock cover. Can you post a picture of what you're looking for? I'm assuming you have a 451...?
limoak,
the lower shock cover is at the bottom of the rear shock. it covers the lower bolt, it is held on with a push pin fastener...ss
