1 - 2 of 2 Posts
Hi, I was recently replacing my factory halogens with a led kit in my 2014 Fortwo, and I noticed that the entire low beam passenger headlight assembly is loose, almost like a adjustment screw is missing. Does anyone know if there’s a way to fix that?
If you are talking about the part inside the plastic housing, then I have seen them break Had one broken when I replaced the lights with a set from a recycle yard. If they are loose, you have to replace them. no way to fix it and stand up to the heat from the bulbs.
1 - 2 of 2 Posts
