I was just running some errands today and the turn signal stopped working. I noticed when I got the fast blinking. I went and got a new bulb and put it in, but no change. The tail light portion of the bulb functions, but neither the brake nor the turn signal will light up. Also swapped the drivers side bulb and got the same results.
Just to be clear, if I turn on the headlights, the tail light portion of the top bulb functions normally, but 3 different bulbs gave the exact same issue in the same socket.
Where do I go from here?
Sent from my SM-G960U using Tapatalk
