1 - 17 of 17 Posts
I hope this is the right section.
I have a 2013 convert. I just got it last Thursday and just noticed today that the passenger seat goes back about 3 more inches that the driver.
Is this normal? If so why. I'm over six foot tall and could really use that room on the divers side.
Thanks in advance
You can modify the seat recline (at least on the 2009) to recline a bit more and give you a touch more room, I believe the seat can be modified (rails) so it will slide back farther. never tried it myself.
Discussion Starter #9
mine links to a post....
"I found the 4 stops near the back of the rail,they look like little dimples made with a punch,I know that sounds weird but that is how they appear to have been made,also look on the inside of the rails and you can see where 4 more protrude to the inside,I drilled out the 4 from the outside then took a dremel with a 1" cutting wheel and ground off the 4 on the inside got about an extra 1" of seat movement to the back."
First time I have heard of this happening. The post I linked to was from teddyray back in 2009. maybe you have some sort of malware in your computer?? I have had issues with pop-ups and use a pop-up blocker that seems to help alot (adblock plus)
I think it's the auto guide app I'm using that's causing it
Try again from a computer using the full SCoA website. AG FREE pushes LOTS of advertisements.
Personally, I have thought about paying for the mobile version but it crashes so darn often that I'll probably stick with FREE and accept that I got what I paid for . . . :shrug:
1 - 17 of 17 Posts
