Hello All, I have a 2014 Smartcar fourtwo coupe/pure with 14,000 miles on it that was a Car2go in its prior life. I’m really Happy with it and have fixed a lot of minor problems on my own. I like how easy it is to change things like transmission and engine oil as well as oil, air and cabin filters. My current problem is that my roof is peeling! There appears to be some sort of textured film/membrane on the roof that is getting water under it via small cuts or holes that I can only assume have occurred over time. I can actually press the moisture out thru the small holes in the film. Where the water can’t be pressed out it bubbles up in various spots with one area actually peeling off and revealing hard roof under the film. I’ve been taping over these areas using duct tape made by Gorilla which actually is about the same black color as the roof. This is only occurring at the corners and sides of the roof. Any thoughts on how to fix this. I’m guessing this membrane/film may be some sort of aesthetic covering similar in texture to what’s covering my dash. Dr. Ray :shrug:
