I will do my best to explain this issue in its entirety
I would also like to add that I have done not just hours but DAYS of research reading every and any post I can come across. both when the issue first occurred (last summer) and now as I revisit the problem
mechanical knowledge level: moderate
I have had a few cars by now and complete all work myself (brake lines, brake parts, fuel line and parts, suspension, no starts, sensors, etc you get the gist)
mostly I stick to GM Jeep and my current truck a 1985 F350 dually
the smart:
2008 Smart Passion Cabriolet 451
purchased about 9 months before the issue occurred
drove hard as a daily commuter into NYC - 80 miles a day for about 6 months - with no issues at all
issue presented itself after the commute was no longer necessary and car was being used as a grocery store commuter
occasionally ABS light would come on but left
TPM sensor light always on-previous owner gave me a folder with all work ever done on smart since ownership in VA
sensors were replaced but were provided by customer
clutch actuator replaced about 1,000 miles before purchase so she was having the issue as well perhaps
the problem:
driving down the road after over 2 hours on a road trip
going about 30 mph when the car started to violently jerk so I immediately pulled over, foot on brake, shift into park, turned off
attempted to start and drive and would start easily but no gears and three lines
removed and replaced as many connecters as could be reached, removed negative battery cable, transmission reteach all on the side of the road
towed home
messed with clutch actuator by removing and greasing
experienced three lines still
purchased after market amazon actuator for cheap and lubricated before installing and reteach
no more three lines and would drive
BUT........
after maybe ten minutes of driving or less when I stopped at a red light it DROPPED OUT OF GEAR or so it felt
a very strange sensation I might add
back to only Park and Neutral
so I hopped underneath, loosened actuator bolts, moved slightly, retightened
good for another five minutes until the same problem
so finally I gave in and towed to nearest SMART dealership 1 hr away
not interested in throwing parts at it as I can do that myself!
there is an electrical fault somewhere and hoped qualified mechanics with a lift would find
their best guess is a new clutch pack and bearing but im not buying it as I am not convinced that is the issue - also quoted 2,800 which is a rip off
it drove just fine before this strange jamb up
little jolting in the shifting but nothing more than any other smart
they did star and sent back with my actuator in (grease hand prints all over cream interior, hood not attached correctly and so flailing in the air on the back of the tow vehicle, and several plastic plastic pieces floating around of which im not sure where they belong-----this is why if you want something done right do it yourself)
currently starts just fine and only Park and neutral
steps I've taken:
replaced and lubricated actuator
battery disconnect on multiple occasions
reteach on multiple occasions
STAR reteach
possible throwout bearing wear
visual inspection of many wires especially near the end of the casing and they are in quite good shape actually but im almost positive one is chafed somewhere
removed and tested TRANSMISSION TCM - good
checked ALL fuses and good
suspect list:
gear shift Motors/wiring
chafed wire somewhere
possible speed sensor issue?
abs timing at the wheel?
questions:
where is the actual CLUTCH ACTUATOR SENSOR? with pictures please!!
in a truly manual car it is near the pedal
the smart:
the problem:
towed home
BUT........
steps I've taken:
STAR reteach
suspect list:
questions:
