Welcome to SCoA!
It always helps others searching for topics if you include more than a generic subject line....
Hi...the battery tested good at auto place with full charge.andi meant when you turn key it makes that clicking sound like it does prior to starting on the norm but it does it for a few seconds but doesn’t start up.theres no dash warning lights or codesFirst you say it will not turn over. Then you say it cranks, but will not start. I am a little confused, I think cranking is about the same as turning over.
But, if it will not turnover... I would start with the battery.
That sounds like the starter. You would get a loud clicking noise but no engine rotation.when you turn key it makes that clicking sound like it does prior to starting
The previous owner of my smart had this problem...Aah, that’s new and valuable troubleshooting info.
I’m thinking that the main power cable to the starter has corroded and isn’t making solid contact any more. Mine rusted out and was intermittent for months before completely rusting through.
If the cable is ok. I’ll second the starter.
