1 - 8 of 8 Posts
2011 Smart ForTwo Electric Drive Passion Coupe Test Drive
The newest version of Smart's conspicuously goofy two-seater is an electric vehicle called the Smart Electric Drive. But can this test car fix some of the ride quality weaknesses that hampered Smart's gasoline-powered ultracompact?
On Sale: Now
Price: $45,587
Competitors: Nissan Leaf, Chevrolet Volt, Mitsubishi iMiev
Powertrain: 30 kw (40 hp) electric motor, 16-kwh lithium-ion battery pack
Range/Economy: 87 mpge, 84 mile estimated range
What's New: Since 1997, Daimler (Mercedes-Benz's parent company) has been testing electric versions of its Smart ForTwo around the globe. The first generation was a 100-car pilot project in London. Now in its second generation of test vehicles, Smart is leasing 1000 Electric Drive (ED) ForTwos worldwide, including 250 in the U.S. Besides the obvious powertrain conversion, the ED ForTwos are nearly identical to their gasoline counterparts. The ED's electric motor and battery pack live in the rear of the car in the same area used for the fuel tank and gasoline engine in the production Smart. Two analog gauges mounted on top of the dash show the remaining battery charge and the power output.
Tech Tidbit: The heart of any EV is the battery pack. The Smart ED's pack is a 16 kwh lithium-ion unit designed and manufactured by Tesla. The pack weighs 326 pounds and provides an estimated range of 84 miles on a full charge, according to Smart.
Driving Character: The gasoline Smart ForTwo is not only painfully poky to drive, but its crude automated manual gearbox is also nauseating, with an unpleasant pause and lurch before each shift. However, considering there's only one seamless speed in this electric, at least Smart has licked half that problem. But despite of the instant torque of the electric motor, the Smart ED is semi-truck-slow. It will reach 40 mph in the same time it takes a V6 Toyota Camry to hit 60 mph. If you want to get the Smart ED up to 60 mph, plan on it taking the better part of 20 seconds. In fact its top speed is only 62.5 mphóso be prepared to spend a lot of time in the right-hand lane of any freeway with the right pedal floored, sucking as much juice as the Tesla-made pack will give you. And considering that just about every vehicle on the freeway is much larger and faster than the Smart, we'd recommend just not going there.
The Smart ED is much more at home on the city streets, hovering between 30 mph and 45 mph. Toe into the throttle from a stop and the electric motor squeaks softly. Mash the pedal and you will hear that distinctive and futuristic whine that accompanies most EVs. Here, it seems louder than others.
Driving a Smart ED requires you to be smartóyou have to plan ahead and drive cautiously. Don't even think about running that yellow light, because you won't make it with the car's paltry acceleration. And we found out about the Smart ED's battery weaknesses the hard way. With the battery fully charged, we drove the Smart aggressively and included about 30 miles of pedal-floored freeway driving with the a/c on the entire time. While trying to maximize our range, we overestimated the miles we had left when the battery indicator showed two bars out of eight remaining. The Smart goes from four bars to three to two to dead very quickly. We ran out of juice three-quarters of a mile from our home and had to tow the Smart to the house. In case you're wondering, the car required a flatbed to tow it and uses a tow eyelet as an anchor point to winch onto the truck. Strangely, that eyelet is located under the carpeting in the passenger footwell. The only fortunate part about running out of juice in a Smart ED is that since the car weighs only 1958 pounds, it's easy to push it to the nearest outletóif you can find one. Still we managed 81.1 miles on a full charge before the Smart ran out of juice, which isn't too shabby. But we wouldn't push our luck on the state of charge indicator again.
Most Smart ED leasees will probably have their garage set up for Level II (220v) charging. But since this is a press car, we had to use the Level 1 (110v) conventional charging. From a completely dead battery, we charged for 15 hours and still hit only 80 percent of capacity. For our second range test, we drove the Smart more conservatively, staying on city streets with the a/c on and never exceeding about three-quarters of the available kilowatts during acceleration. We traveled 77.4 miles until the charge indicator said we had 10 percent of the battery left. So Smart's estimated range of 84 miles seems about right.
Favorite Detail: Air-conditioning and heating systems deplete battery power on extreme weather days. So Smart uses a pre-conditioning feature, like most other EVs, that will cool or heat the cabin of the car while it's plugged inódrawing energy from the wall socket, not the battery pack. And the system can be programmed to time itself for your next drive, so you'll have a cool interior and a fully charged battery.
Driver's Grievance: Aside from it's tortoise-like acceleration, the Smart ED falls short of more mainstream cars in the same ways a gasoline Smart doesóparticularly the ride quality. Over large bumps, this tiny car rides like an empty 1-ton pickup, bucking so hard it provokes conversations with your passenger that begin, "Is it supposed to do that?"
The Bottom Line: The Smart ED is still a test program, so we can forgive some of its shortcomings. We're told that production cars will arrive in 2012 with a range of 100 miles and a new Daimler battery pack co-developed with Evonik. The battery and presumed power upgrades would certainly make the production Electric Drive a more satisfying car. We just hope the chassis engineers spend some time retuning the suspension and the electronics team comes up with a more sophisticated system to display and calculate remaining range. With competitors like the Leaf carrying smooth-riding suspension and a high-tech driver information system, the existing Smart platform could be too outdated to compete.
Source
The reviews of the ED seem more bi-polar than my ex girlfriend.... :rofl:
I read it and it does sound like they tried to like the car, but couldn't. Sounds like a fair review.
Think about it: this car is engineered to start at $13,500 USD. If you pretend to sell it for $45,857, you are going to compare it to cars that cost.... $45,857. Heck that's BMW 5-series territory.
How can a review of a smart ForTwo that costs almost the same as a BMW 528 not be incredibly harsh?
You guys do realize that whoever leases this car will never recoup their money, compared to purchasing gasoline in the regular version, don't you?
Not even with the $7,000 tax subsidy paid to the driver of a $46,000 car by all of us the other regular taxpayers who can only afford $14,000 cars.
I read these reviews about cars that I have driven extensively, and always think
"Gee, how come the car I drove was so vastly different from the one they reviewed?"
I have over 500 miles logged in the electric smart at my dealership and have never experienced any of the issues they mention?
Of course, I KNOW HOW TO DRIVE THE CAR?!?!?!?!
Yeah, I don't get it. For $46Gs you could buy a ICE-powered smart and drive a LONG time with the rest of the money. EVs are not now, nor will they for some time be ready for prime time. You wouldn't need the tax breaks to get people to switch, they would switch because it make sense. Just more fuel to the [debt] fire. It's just a really stupid idea who's time hasn't come.
15000 mi/yr at 35 mpg and $3.5/gallon yield a gas bill of $1500/yr
$46K-$16K = $30K
Not accounting for opportunity costs you could drive your smart for 10 years and still have enough money left over to buy another one!!
EVs are for the math-challenged or people who have so much money they just don't care. I SO much hate all of the hype and I make no apologies fort the rant.
1 - 8 of 8 Posts
