1 - 3 of 3 Posts
Does anyone know if the Pure (451) is equipped with the wiring for power windows? I'm looking to swap the crank out for power windows only if the wiring is provided.
Thank you,
I've just completed this conversion.
I got this set from ebay: Elektrische Fensterheber Smart 451 | eBay
The wiring in the door is not there. You will need a new set for both the doors.
They hook up to a plug underneath the mirrors on both sides. Easy job.
YOU WILL ALSO NEED a separate control box. It is situated underneath the dash next to the SAM unit. You should also find some loose wires there taped to the main harness. These plug in that control unit. Part number is: A 451 820 00 26 / 002 or according to Mercedes WIS: A 451 900 34 01. Should be the same unit but different number. I've also seen them with A 451 820 00 26 / 003. don't know what the difference is..
Link to ebay: Smart ForTwo 451 Steuergerät Bordnetz A4518200026 / 002 --2805-- | eBay
That is also easy plug in.
Next you must activate the power windows at the dealer! Otherwise it wont work.
Pay attention to the fact that the old mechanism is attached with 2 screw and 2 (BIG)rivets!
Good luck and let me know if you managed!
Sebastiaan
Why not just swap out yours for one with MORE options... Might be worth it to call it an Upgrade with all the extra Goodies...
1 - 3 of 3 Posts
