451 smart fortwo Pure
Me and my mom installed a speaker in my smart today - had no issues until it came to sliding the panel back on, any tips or tricks on how to get it back on? thanks!
2015 smart Fortwo Passion Coupe
Line up the little tab with the handle, push the door skin all the way forwards (to the front of the car), then rotate the skin upwards to match the angle. Then reach under the door skin (at the bottom front corner) and push it in hard. Slide your hand up and push the rest of the door skin over the front edge of the door. Then I lightly "slap" the top of the door skin clips into the door. The top of the skin should then stay attached to the door. Then push the entire door skin towards the back of the car and it should stay. Then you can just screw in the big T25 screw to hold the door skin in place. From there you just reattach the mirror and everything else.
You can also check the Evilution post about removal and there's a small section about re-installation, albeit no pictures.
  • Love
Reactions: T42
