1 - 2 of 2 Posts
it is hard for me to get on the ground let alone getting up so i only do it when i can stay there awhile and do some work.
are the front sway bar brackets accessable without having to remove the front belly pan?
i have seen some companies install a zerk fitting so the rubber bushing/sway bar can be lubed to eliminate squeaks. so i want to put one on each metal bracket and drill a 1/8 hole thru the bushing to the bar and squirt grease up there. i have tried cable lube, silicone, wd40 etc
1 - 2 of 2 Posts
