My box stock, passion for two, 2008, radio has finally crapped out. Well, essentially crapped out.
When set on FM 1 or 2, everything is copasetic. When set on CD, every thing is fine, unless I should venture to turn the volume up beyond 18, then the sound essentially quits. And when set on 'Aux" same as with CD.
I'd be happy with an original radio like the one I have that works normally. I'd also be happy with an aftermarket radio that is essentially plug 'n' play. Recommendations much appreciated.
Lastly, let's not blame the speakers cuz they are tip top so long as the device is set on FM1 or FM2.
So: I need one of two items: 1) a box stock radio that works; or, 2) an aftermarket that doesn't cause me to reach into the many a quaint and curious volume of forgotten lore from my Navy stint as an ETR-3 back in the distant day.
¡mucho gracias! in advance.
