1 - 4 of 4 Posts
2017 453 Passion ED/EQ
My issues have dropped away for the moment after removing, opening up, cleaning and re-lubing the actuator last week.
This is the second time I have done this, the first being Nov 2012.
Because of clutch wear, re-seating the re-lubed actuator to abutment plus 3 graduation lines, as shown in the "AR25.20-P-0123MCC" paper (found elsewhere in the forum) fixed my clutch issues.
Let me repeat, I did not try to put the actuator back in the same location I found it as others recommended, instead I followed the abutment plus 3 grad line procedure.
Prior to the re-lubing I was getting awful gear grinding and clutch slipping , plus a P0805 Clutch Position Sensor Circuit error code.
The 08 smart is at +125,000 miles. I drove it in the snowstorm today and it behaved quite well!
I will keep this in mind for my wife’s 09 451 . Thanks for the helpful info.
1 - 4 of 4 Posts
