When I turn the headlights on the rear driver side does not light up. Turn signal and brakes works using the same bulb. Swapped both panels from the passenger side, vise versa, works and the driver side still out. Tried new bulbs, same problem.
Not sure? Is the wiring harness, a specific wire that connects to the socket panel bad? Or is there something odd with a module or even if there is a separate fuse for each side which doesn't make sense.
Thanks!
Thanks!
