I bought my car with 28k on it and the wheels were not bowing out at the bottom like they are now. Will this cause the tires to wear on the inside edge...and what is the reason for this?
Negative camber usually doesn't increase the high speed stability, as much as it increases grip at those wheels that have the negative camber. Smart did this so that the front wheels with slide first when cornering fast, believing that severe understeer would be safest in a short wheelbase car like this. The desire to have severe understeer is also why the front track is so much narrower, and the front wheels have nearly zero camber.Oh, and the reason is to increase stability at speed.
