1 - 20 of 48 Posts
My rear window washer has stoped shooting out fluid.The front works fine and you can hear the pump working when you push for the rear but nothing comes out.Any ideas?
Hmm, not sure. If you were in a colder climate I could suspect freezing fluid in the hose, but since your in Florida no idea. :confused: A trip to the Smart Center is needed. :smartje.wt.zw:
...remove small rear panel on the left side...peel back sound deadener...small blue hose is attached with the wire bundle in that area...you may have to pull the white foam insulation bag...there's an electrical plug under some foam shield but the hose has a push in fitting next to it...ask me how I know..ok..just fixed mine today
jetfuel
Mine stopped working about a month ago, in the same way as yours turk. Because it's not urgent I've been putting off a trip to the dealership until I can get the updates at the same time.
windscythe...try this ..use the rear washer for a few seconds..step behind the car and see if you have washer fluid behind the left rear wheel...if you do...it came of the fitting plug...
jetfuel
jetfuel
Glad to hear you solved the problem. Did you get any photos of the hose and connector? :)
turk1949
Thanks Jetfuel (etal),
This is a great sight, ya'll are always helpful.I'll see if I can find that panel (any photo's would help)and give it a try!
..no photos..my camera was at work..I'll shoot some this afternoon if you still want to see it...I relocated the plug/washer fitting for easy access next time...you can see it by just removing the side panel...
jetfuel
Jetfuel, I already had a friend check behind and under the car while I used the rear washer. I did that just after it started happening- no sign of anything leaking.
ok..I'll post some pic of the fitting...remove hose there and spray again...just to see if pump is strong enough to push fluid without restrictions...
jetfuel
PS...you got fluid in reservoir...right?
I had times when there was fluid in the reserve but it was frozen solid. Not all those that indicate 'anti-freeze' on the won't freeze up. :( Of course this is unlikey since you are from Floriday.
...here we go...check fuse 20...make sure you got fluid...turn pump on...can you hear it run?....does the windshield washer works?..if the front works but not the rear check this fitting in the rear area...the blue hose...you may have to pull the white insulation to get to the fitting...install it first then the plug/fitting assy...you can pull the fitting/hose assy appart and test to see if you get any fluid from the hose when the pump is on....
...LUK...
jetfuel
Thanks for the photos and the tutorial jetfuel! Not sure if I'll tackle it myself or just take it to the dealer but it's still useful to know. I'll let you know if I open it up and take a look.
Jetfuel, I plan on as much DIY'ing as I can on this thing to learn it inside and out. Thanks for the help that you gave here and in other threads!
~Jas...
...LUK...
jetfuel
Thank you very much for posting this! I just fixed mine in 2 minutes. Gotta love the simple DIY fixes!
many thanks for posting this solution to my washer problem. Your advice was excellent and the photo very helpful. My problem has now been sorted. Although you are several thousand miles away from me, you have managed to sort my problem at zero cost.
JetFuel, thank you. I got the same problem in my wife's Passion. The blue hose was disconnected. It was a really loose fitting so I use some plumbing teflon tape to get a tighter fitting. Again, many thanks.
my rear washer only dripples a small amount of washer fluid on the window,, but there is a big leak in front of the left rear tire.
Do I have to remove the exterior black panel under the door, or is there an easier way?
1 - 20 of 48 Posts
