1 - 10 of 10 Posts
The outer section of the door nub broke off and i pushed the nub in further by mistake. How do i remove the key mount on the door to get that plastic piece out? Does taking the lock apart get access to the nub?
I drilled a hole through the plastic piece and tried to screw in a bolt to pull it out and it did not work. This was a few weeks ago. Now, i assume i need to take the lock out and take the metal cover off and reinstall.
I know what happen. The cap or cover broke off from the blade part that slides into the lock cylinder, and that part is jammed Down in the lock cylinder. Samething had happened when I got my car. My lock had to come out of the door and be taken apart to remove the piece of plastic jammed in the cylinder.
I wish I would have used a professional locksmith. I would be able to unlock my door with my key.
Good luck.
Discussion Starter · #7 ·
Good luck.
Yea, thats what happen. How did you get the lock out?
Discussion Starter · #10 ·
Any tips on getting into my car without a key? I was thinking of using a flat bar ( garage door opener motor bracket) and pulling the back window open slightly and pushing the back window nubs forward to get the back gate open
1 - 10 of 10 Posts
