I have 3 switches on one side and 1 switch on the other side. Is there any problem with evening the switches out?
Use extreme caution should you decide to try this because the signals are switched through the SAM. If the SAM is damaged, it may render the car inoperable.It would probably be fairly easy to 3D print a replacement cover to accommodate more conventional rocker switches. But you’d need a matching circuit board or point to point wiring for connecting. The existing switch bank comes apart pretty easy. They made 8 different switch banks, depending on the particular combination required. Seems pretty stupid that they didn’t make it more modular. One of the more toy-like components.
Do you know if the other end of the wires are terminated, i.e have connectors on them?from what I can see on both switches is that they are fully wired from the factory and you just replace covers for the appropriate option
Oooooh! I would love to get my hands on one of those solar roof panels!....the car2go is a weird vehicle, not falling into any designation especially with the 100 watt solar powered roof.
Wow! Thanks for the tip! I send them a message!There is a auto recycler in Coquitlam BC who sells them for $500 CDN or about $380 US, I believe the name is Prestiage Auto recyclers
