just got done replacing my driver side door lock / latch.
I had to remove the mirror, outside door handle and the outer door panel.
I followed evolution’s instructions for all of the removals. The only problem I had was disconnecting the power to the mirror. There is not a lot of room and the plug was very tightly connected. Once I got the mirror off everything else came off as per the instructions.
I could not find instructions for the actual removal of the lock assembly, but it is pretty much common sense. Remove the three torx screws on the edge of the door. There are three cables you must disconnect. One goes from the outside door handle to the lock; one goes from the lock to the key lock on the outer handle; and one goes from the inside door handle to the lock. Be careful not to damage the cables when removing. The new lock from MB had the cable for the key lock already connected, so you need to reuse the other two original cables. When disconnecting the cable from the indoor handle be very careful not to hit the window with the lock or you will be replacing a window too. The whole job took me a couple of hours but probably could be done quicker if you have experience in removing your panels.
