After the discussions we've had here about the EV battery "bricking" in conjunction with the 12v battery going dead, I've decided to do a preemptive strike and just replace my 12v battery to head off any potential cata$trophe. I'm seeing no issues and I have had the service campaigns done, but the battery is original to my 2014 coupe. This goes against everything I've ever done in the past when I waited until the 12v battery told me it was time to be changed. I would often go as long as ten years, but there was little downside. That may no longer be the case with our Smarts.
So I'm seeking input from those of you that have changed the battery. Looking for things to watch out for and things to make the job go smoothly. My plan is to hopefully install the correct battery from Mercedes to avoid any issues with size and fit. I think that some of you have used a Group 47 battery, but I've read reports of some having to make some modifications in the hold down, etc. I figure those issues can be avoided by using the correct Smart battery. It's a very tight fit no matter the battery used. Cost is about $170 which isn't that much more than a battery from a McParts store.
Does it make any difference if the EV battery is fully charged or not when replacing the 12v battery? I've seen one You Tube video where it was suggested that the plastic cover in the center between the passenger and the driver's side be removed, but I've seen others where that wasn't necessary.
Any advice and experiences appreciated.
Thanks.
2014 EV Coupe 19,500 miles
2014 EV Cabriolet 17,500 miles
Thanks.
