Hey All,
I hope all are well and coronavirus free.
I have been having intermittent stability control issues with the ABS cycling on sometimes mild curves. Thinking that the yaw sensor might be failing, I replaced it with a used one from eBay, but, as I’ve seen before, any time a replacement part is installed, the SAM/ECU determine its a new part and turn on the “yellow triangle !” light.
Save a trip the the dealer or buying a C3 or C4 MB Star Machine, does anyone know of a device or method to get the SAM/ECU to recognize the replacement part without a 2 hour drive and $160 trip to the MB dealer for what amounts to a 3 minute job?
I’ve tried my OBD2 and BlueDriver tools and reset everything they are capable of resetting with no results.
Any assistance would be appreciated!
Thanks
-v-
It's just possible the used part is not working, or the yaw sensor wasn't really the problem......:unsure:
I don’t think so. I saw the same behavior when I replaced the ABS pump a few years back. Plus, if I put the old part in, the problem goes away. I suppose the replacement yaw sensor could be faulty.
Has anyone else seen this?
