Here's a good list to look at: https://www.evilution.co.uk/mod/453-alloy-wheels.htm
On the 453, keep the rear tires 20mm wider than the fronts and the overall diameter close, centered around 23.0" to not have TCS issues.
The OEM (and Brabus) tire sizes all follow this ratio.
The 23" diameter 225/35/17 size has been discontinued by the manufacturers so there is no need for a rim wider than 7" now.
The front tire is the fitting issue as Smart chose an odd size, and, limiting the rear to something 20mm wider...
Ex. My 453 came with 16x6 Front and 16x6.5 Rear rims with 185/50/16 Front and 205/45/16 Rear tires.
The only thing out there in 185/50/16 is stock Contis...
But if you go down to a 15" rim size, there is a 23" diameter 185/55/15 and the 205/50/15 (or 175/55/15 & 195/50/15) made by several tire manufacturers.
To summarize, find your tires first, then you'll be able to nail down the rim sizes.
I did work out an 'All Weather' set for my 453 but I had to use 165/60/15 Front and 185/55/15 Rear on a set of 15x6 rims (same width wheel all around, 20mm different width tires mounted on them).
For these sub 100hp cars, wider is not better because the wide tires are discontinued in 23" diameter.
