1 - 3 of 3 Posts
Just bought it today. Roof rattles on bumps. I can lift roof up about 1/2" on passenger side. I read these need to be reglued sometimes. Where in MN can I have this fixed? Or is there a way to do it myself?
Any help appreciated!!
Thanks
From the FAQ on smartusainsider.com
3) Why has my panoramic roof lifted off the tridion cell (glue failure)?
Glue failure may have been from using the wrong glue if your roof needed to be replaced. The applier needs to read the instructions carefully as there are two kits: one for the panoramic roof and one for the full roof. They look similar but will only bond properly for their designated roofs. For this reason, it's important to visit your local smart center to insure installation is done properly should it be needed.
Best bet is the smart center if you trust them; if not, a good body shop that can get the correct adhesives, IMHO. :)
Your smart center or any auto glass shop should be able to re-glue your roof. Just make sure they use the correct adhesive material for re-adhering your roof panel.
1 - 3 of 3 Posts
