1 - 4 of 4 Posts
I am trying to activate running lights on my 2012 Smart Fortwo. The owners' manual gives the following instructions:
- turn off ignition
- switch on high beam flasher while simultaneous pressing the door lock button
- an acoustic signal sounds
It simply will not work for me. Any suggestions?
Stealership.........................
I believe if the lights aren't installed at the factory,you MUST have the stealership,a.k.a. smart center activate them..............
By activate, do you mean that you bought a set and are trying to turn them on yourself? If so, you have to have a dealership do it. :/
I just turn on my low beams when driving. This is because of the small size of the Smart. I want to be seen during driving.
MLogan
2014 Passion
Smyrna, TN
1 - 4 of 4 Posts
