1 - 3 of 3 Posts
2018 coupe. Can't post links.
Looking for the pin out for the SAM. Mainly the fuel pump. N11-5 pin 11 but it lists Fuel Pump, ECU pin66,73, O2 down, Coil Packs fuse 10.
Looking to power the pump directly to see if the pump works or not if needed. Just not sure if I can directly put power to the removed harness since it lists other stuff there.
evilution.co.uk/index.php?menu=wiring%20&%20pinouts&mod=821
fq101.co.uk/how-to-guides/fortwo-451/electrical/503-sam-relays-1
Thanks
Thanks
You must be in the U.K. The last gas engine smart in the U.S.A. was 2017,so no knowledge on 2018..................
1 - 3 of 3 Posts
