I've a 2009 Smart Brabus Cabriolet. Didn't use it over the winter, battery went dead, charged it, then replaced it. I now have no response; no interior lite, no clock, no radio, no dash lites & no start! Checked the fusible link (200 amp fuse) & all fuses on front of fuse box, but don't see fuses #32 ,33,34 & 35 on rear side(?) of box. Didn't hook up battery incorrectly. Any help'd be appreciated. Also does anyone know how to put into neutral from park w/o car running?
He said he "replaced" it, but a test seems in order :wink:
You need to "unsnap" the sam and swing it down in order to access the back for fuses 32,33,34 & 35 :)
AND.......
To The
Had AAA Road Services out, said new battery was aok. They also hooked up their jump box & got no response. The battery checked as having 669 cca & putting out 12 v. Any other thoughts?
Unsnap the sam? I removed 2 Torx bolts & the fuse panel drops down, but don't know if I need 2 unsnap several plastic clips along the sides of the panel. Don't want to make the problem any worse.
