The title pretty much says it all ... I have a 2009 Passion that the battery went DOA from sitting ... I did have issues prior to that where the battery would be sucked down do to the parasitic issues commonly found in the SMARTs. Knowing this I purchased a new battery but could not find one...
Does anyone recognized from the pic what that wire is that is not connected to anything. One wire appears brown and the other black (but hard to tell the black wire with my light) There are 2 plugs disconnected also in pic. My cooling fan is not working (the fan works jumped). I did replace a...
I have been a smart car owner since 2008. I am on my 2nd smart. I have a 2009 smart passion convertible. I have serviced both my cars 99% of the time.
My current smart has a problem I cannot figure out.
When you go into 1st gear or reverse the transmission does a kick, the rpm drops than kicks...
Hello, 2004 0.7 smart for two , left rear abs / esp fault, continuous fault code will not erase, and car limited to 2500 rpm, replaced reluctor ring & abs sensor, still fault, are the pumps prone to fail ? have not checked wiring from sensor to pump yet, any fuses? any help would be great :-)
