1 - 4 of 4 Posts
Anyone know how to erase the code? Was told it may be the seatbelt sensor? It does not show on a regular ob2 code scanner...imput please help thanks in advance! 2008 cabrio 451.. looking to put a turbo kit anyone in new york area.
Just to be clear, the airbag light above the rearview mirror id on when there is only one passenger, with 2 people in the car it will be out. If you are talking about the airbag light on the dash, chances are the sensor is bad, or a wire got cut, or removed under the seat with the battery connected. The only way to shut it off is with either a high end SRS scanner or the factory STARR computer. (not completely sure a high end SRS scanner will shut it off)
Negative there is a light by the speedometer Under the seatbelt light with an airbag in front of it..
1 - 4 of 4 Posts
