Vendor
Vendor
Discussion Starter · #2 ·
Purchase our most popular Power Pack Upgrade and save an additional $150!
Power, Response and Savings!
By combining two of our most popular and reviewed products into one pack, the MAXPower ECM, and GOPedal, we are able to offer them to you for even less than buying separately!
The MAXPower is designed to give your smart a solid 20% increase in horsepower and torque in the useable, 2-4k RPM, range. Unlike other tunes and ECMs that chase peak horse-power ours is designed to generate useable day to day power. This is the kind of power increase you will feel on your daily drive to work.
The GOPedal is an interface that installs between the throttle pedal and the ECU. Once installed it changes or remaps the signal from the throttle to the ECU. To put it simply, what the ECU used to see as 20% throttle input could now be 30% or 40%. Additionally, with the Bluetooth version, you can program your own set of maps on top of the ones we have already loaded. Allowing you to find that perfect sweet spot for your vehicle and your driving style.
More information and pricing can be found on our website
smart fortwo 453 MADNESS Power Pack - Stage 1 Online Store - smart car Parts and Accessories
Let us know if you have any questions
Vendor
Unlock additional power from your smart and save at the same time with the MADNESS Stage 1!
The Stage 1 kit for your 451 or 453 will transform the way you drive!
For the 451 you'll be getting an autoflash to remap the transmission, quicken up the shifts, and adjust the shift points. You'll also be getting a GOPedal to remove the input lag from the drive-by-wire system and create a more responsive or aggressive throttle response.
The 453 gets a MAXPower ECM to increase engine output by up to 20% and a GOPedal to help you really use that extra power!
453
451
smart fortwo 451 MADNESS Power Pack - Stage 1 Online Store - smart car Parts and Accessories
Vendor
Pep up your smart with an increase in performance and throttle response from the MADNESS Stage 1!!!
Let's face it the smart is far from a performance vehicle. It is low on power and it takes a long time to shift gears. Well, now you can change that!
The Stage 1 package will increase power output by up to 20% and provide an immediate throttle response through the MAXPower and GOPedal modules!
Plus it comes with a 30-Day money back guarantee.
More information can be found on our website
451
453
And toss in a set of them pretty read Ignition Coil Packs and I'll drive form the California shop to the Texas shop for a test run. While I'm at the Texas shop bolt on the Lambo door hinges and the Harlem Edition will fly right on back to NYC Pumped up, doors flapping........
.....ahhhhh let a man dream. :nighty:
Vendor
Discussion Starter · #6 ·
Oh, we'd be more than happy to help with that project!
Throw on a couple GOPros and make a video series of it!
Vendor
Discussion Starter · #7 ·
Improve the power an response from your smart with the MADNESS Stage 1 Power Pack!
There is no quicker or easier way to improve the feel and power of your smart than the MADNESS Stage 1!
By combining two of our most modules you can increase power by 20% and eliminate input lag!
451
453
