1 - 18 of 18 Posts
Service Bulletin - Discharge/Charge Procedure Prior to Battery Status Check
This bulletin covers the procedure needed to obtain a valid current capacity measurement when performing a battery pack scan using an appropriate scanner or the open source device - or when taking the car to a MB/Smart workshop to have this done.
As far as I have heard or read, no MB/Smart service writer in the US/Canada has ever provided the following "Important Customer Communication Information" to any Smart ED owner:
Date: May 6, 2014
Order No.: SM-B-54.10/09
Group: 54
SUBJECT: MY-All, Model 451.390/391/490/491 Preparation for Performing Maintenance Service or Status Check of High-Voltage Battery
When doing service maintenance for smart electric drive 3rd Generation vehicles the high-voltage battery is to be tested (AP54.10P-5451MEX) as per maintenance sheet (AP00.20-P-1229MEX) in the Additional operations section. To ensure that any losses in capacity are reliably determined during the test, the high-voltage battery has to undergo a specific discharge cycle before conducting the test step.
Important Customer Communication Information:
The customer must be notified when agreeing on an appointment, i.e. before the workshop date, that he must perform the following step before the maintenance service, insofar as this is not part of the customer's normal driving cycle:
^ Drive vehicle (discharge) to < 40 % SOC (see left-hand round "SOC" dial on instrument panel).
^ Leave vehicle parked for approximately 2 hours (no driving, no charging).
^ After this idle period of approximately 2 hours, connect the charging cable, and fully charge the vehicle to 100 % SOC.
^ The vehicle can then be operated normally again.
^ By discharging to < 40 % SOC, having an idle period, and then the renewed charging process, the high-voltage battery undergoes a capacity test. The test result is then read out during maintenance. This cycle must be run through once, 3 weeks before the maintenance service. If, by contrast, the vehicle is only ever driven when in the high SOC range, this test cannot be successfully undertaken.
Important Workshop Process Information:
When conducting the maintenance service as per maintenance sheet (AP00.20- P- 1229MEX) the high-voltage battery (AP54.10-P-5451MEX) must be tested as stated in the Additional operations section.
^ If this procedure can be conducted, the corresponding capacity value is then shown. The test log is to be included with the maintenance documents, and handed over to the customer when requested.
^ If this procedure does not produce a valid value, then the procedure within this maintenance service shall end here, i.e., no further tests shall be made.
^ In the event of customer complaint, i.e., where the customer makes an express request, a capacity test can be conducted at any given time using XENTRY DAS through the "High-voltage battery - Complaint" guided tests, and it can be settled taking the applicable warranty policy into consideration.
^ In this case, please notify the customer that the vehicle should again be discharged and charged, shortly before the next maintenance service, to enable a valid and current capacity value to be determined (see "Customer communication" section).
Notes on cost settlement: [deleted]
Five years later and yet NONE of the smart Centers were aware of this procedure?
Makes you wonder just what the highly compensated folks at smart USA, Atlanta do/did 9-5???
We have mentioned the test procedure steps Yinzer mentioned in Post #1 several times on the forum. The first time I recall someone mentioning it, it was reported that the European service centers told the customers about it but the US service centers never did. I always go through those steps when I test my batteries and we try to remember to tell anyone buying our test units about it. If a battery test is done without going through those steps, then the reading will show the last time the steps were "accidentally" followed. I think Jon Renner's reported test results are an example. IIRC his results showed 331 days or so since the last self test.
2014 EV Coupe 18,000 miles
2014 EV Cabriolet 12,500 miles
This is good info, Yinzer. So if I'm understanding this correctly, those procedures must be conducted within three weeks of the appointment to get an accurate capacity reading?
The battery test shows results from the last time the parameters were met. The closer you do it to the test, the more up to date it will be of course. I usually do mine the day before I test.
The capacity change is quite gradual (a couple percentage points per year typically), so I wouldn't make a huge deal of whether the last measurement was a day, a week, or a month ago.
Yeah, I've never heard these instructions before but I will definitely be doing it before my next appointment.
For sure. I just rarely get below 40% and definitely don't wait 2 hours before charging it when I do.
Thanks for this. Over the winter I got used to a reduced number of miles on the Guestimator but expected it to get back up to 80 in the warmer weather (that was very delayed here in Buffalo this year). It didn't improve much. I figured that my charging every night was probably catching up with me. I drew the charge down to zero and charged slow (110). The Guestimator responded from low 50's to high 60's. Did it again from zero and two more times at <20% and the number is now in the mid 70 miles. I'll try just going under 40% and doing the wait and see if it improves any more than it has. Thanks again.
"I drew the charge down to zero" (a few times) [RZ14]
You are doing this by driving the car, right? And because you have lost faith in the car's BMS to effectively bottom_balance/top_balance all by itself?
VR
When working on the battery diagnostic tool, I often had to draw the battery down and didn't feel like driving the car to do it, so I would just run the air conditioning in the garage which would run the battery down without any risk of getting stranded, plus I could do something else and just monitor it periodically.
When it went to 52 miles I knew I had to do something different.
After the "treatment" last night it leveled at 76 miles.
Gained about five over the results of the previous four charges.
Sorry to have missed the lecture series given at local MB dealer re: balancing your Smart_EV battery. I'm told there was a quiz !! But I recently did learn one new thing about my Smarty, that the ">47" on the dash is the estimated mileage remaining in battery, and not the number of days until Service Required. A small step for a man . . .
VR
Discussion Starter · #14 · (Edited)
The changes in the range estimate you see are just due to changes in ambient temperature (warmer=longer range) or your driving behavior improving the stored value of past energy consumption (i.e. miles or km per kilowatt-hr), NOT any change to the battery pack health.
You can also always turn the right stalk to the "Reset" menu, and push and hold the left button to zero-out the miles driven and cumulative miles/KWh and the range indicator will go up to a higher default value.
The range indicator on the Smart is very approximate until you are down to the final 20-30 percent and can cause more range anxiety than it is supposed to prevent. I prefer to just use the trip odometer and SOC meter to estimate the range left.
Discussion Starter · #15 ·
VR
As they say, "RTFM!"
I have an update on the "battery reconditioning."
The improvement was not really there.
The guestimator eventually soothed back out to 53 as before.
A couple weeks ago, I took it off the charger to go to my brother's, a bit over my usual round trip distance.
About 2/3 of the way there, I looked at the dash and it showed 62 miles left, 11 more than when I left!
I got there and did what I went to do and got into the car to leave.
No Go, the dash said there was a fault (I forget the wording).
I tried to google the phrase but there wasn't any remedy that I saw.
After trying to learn and looking at stuff, I tried again and the car worked, but at the previous level, about 35 miles left.
I have a theory I like, but thought I'd open it up to any techs familiar with the ED to see what they think.
With my 2016 now at 10,000 miles I've never bothered with any of this stuff. A shopping trip is 20 miles each way to the city or else 5 miles each way local and charging and range seem unaffected over the past year or so. The 12v battery is original but is still functioning as I leave the car ON while waiting for the ferry so as to maximize the dc-dc charging time and also keep it (12v disconnected!) on float charger when I'm away for weeks at a time.
I just figure that each 10% on meter is 7miles! (ie 40% I have 28 miles left!) This has always worked for me.
1 - 18 of 18 Posts
