I tried to change the time on the radio display as indicated in settings but when I get to the Clock part, the change the time box does not light up and thus I don't get anywhere. Anyone help?
I did that. When I go into Clock, there are two buttons. Set Format and Set Time. Only Set Format is highlighted. I can go in there and do that. Then when I try to set the time in Set Time, that button is not highlighted and you cannot push it. Any hints?If you have the "Smart media system", the clock is set on the media system (aka "the radio") (and presumably transmitted over the CAN bus) under System:Clock:Set Time not under Settings:Time:Set the Time on the display behind the steering wheel.
Got it the last day of May. So far just a little over 1000 miles as I work half of my time from home. I miss some features of my 451 but I'm happy with the 453.Arturo, when did you get the electric smart?![]()
