Video shows much movement in the passenger motor mount. Check the prices for a set and consider changing all three motor mounts
Do i have to remove the throttle body? I from the videos i seen some people remove some went around it.The front one is easy to install. The passenger one in the video is not to bad. The driver side one needs the air intake baffles moved so if you are thinking of going to the silicone intake tube set up now is the perfect time.
