I will be purchasing a kit from SFR with all the options possible, (Go all the way or nothing). My only concern is with the install of the oil cooling lines. The feed and return. Will I be drilling into the oil pan for the return? If so, I'll need a new oil pan gasket correct? I'm hoping there are ports that are on the engine already. Seeing how in Europe it came stock with a turbo. Any help would be greatly appreciated. Thank you.
P.S. I will be doing a 1/4 run a few times before and after the stage 2 install.
