Here's the get me home fix.
Small HOZ strip of tape marks place to put fingers to pull/up console cover.
Same spot on other side. Aprox !0 + 2 clock positions.
Long VERTICAL tape points to position where you will see the YELLOW lever under the left bottom edge of cover.
1. Slip fingers slightly between bottom edge of the cover and the carpet. Pull up and back ,and snap the cover loose, but do pull up over an inch or so. Be gentle.
Prop up front of cover about an inch.
2. On the ground, looking in under the cover from the drivers side, you can see a yellow lever just inside the cover. WITH THE KEY ON , Lift this yellow lever while wiggling and pulling the shifter down, out of park. (Wife used a pen to lift the lever).
3, Do not try to use Park again until the whole shifter box has been replaced.
4, Feed back is appreciated so that we can refine this fix.
A2Jack
A2Jack
