Shifting Issue (not from P to D)
918 Views 3 Replies 4 Participants Last post by  dhlairbusb4
While driving, my car will start jerking before or after a shift, but this only happen under a heavier load. If I let off the accelerate a bit and slower reengage the shift is smooth, The problem also can occur going up hill or in gear with heavy acceleration. OBD2 graph shows a neutral shift between gears, someone mentioned a false neutral?? (I attached the graph to accurately show this). The problem is more frequent when the A/C is on.
I recently replaced the bottom mount because it had worn completely through and had been that way for sometime. I was thinking maybe the Clutch Acuter readjusted for the broken mount and can't find correct position. I have also replaced the Fluid in the case and made sure it was the appropriate weight. 75w-90. no slipping out of gears occurs and it shifts from P-N-D fine with the rare hiccup
No engine or Transmission codes are being shown on OBD2 either, thus making this more difficult to diagnose.
Re-position Clutch Actuator? Switch not communicating? Actuator motor dying?
See less See more
1 - 4 of 4 Posts
" I have also replaced the Fluid in the case and made sure it was the appropriate weight. 75w-90...."
I hope you used GL-4 and NOT GL-5 ?????
2
Remove and clean/lube the gear shift motors and clutch actuator. The motors are a pain, as the air box is in the way.
Once removed, you will not want to put it back in... see pic for my solution. I am waiting for my madness cold air pipe
that is still on B/O.
See less See more
1 - 4 of 4 Posts
