My 08 smart is coming up on its 60K mainentance. I have been driving it on some nasty Boston roads and wondering, how do you know its time to replace the shocks on this car?
The simplest form of shock absorber "test" is known as a “bounce test.". . . how do you know its time to replace the shocks on this car?
Yep, and you might as well wear a sign on your forehead when you walk into the dealership that says SUCKER if you do that. Then they will look for something wrong, and lighten your wallet an appropriate amount for your trouble...First thing I'd do is ask the tech to take a look at your shocks when you take the car in for service. In fact have him check the entire front suspension. Chances are you will need other suspension parts before you need shocks. If you use a dealer that gives you a loaner, then compare its ride to yours, although in the six years or so since yours was built, there have been some improvements, but at least you'll get an idea.
Besides a good dentist the second most important professional in your life should be your mechanic. Unless you are rich and just buy new cars all the time.Yep, and you might as well wear a sign on your forehead when you walk into the dealership that says SUCKER if you do that. Then they will look for something wrong, and lighten your wallet an appropriate amount for your trouble...
Well, I guess that's the great thing about being me...Besides a good dentist the second most important professional in your life should be your mechanic. Unless you are rich and just buy new cars all the time.
It's your mechanic's JOB to find things wrong with your car. Would you want to go to your dentist and have him/her gloss over a few cavities and have them turn into lost teeth or root canals?
It's up to your mechanic to alert you to the problems with your car and advise you of a proper repair strategy. We're not all crooks looking to lighten your wallet but we're not doing our job if you bring us your car in good faith and we let it roll out the door without advising you of it's issues.
Before I retired from my shop I enjoyed working with the shade tree mechanic. After all, I started out that way myself. Eventually, they would encounter a job they couldn't fix themselves and because I had lent them tools, information, or advice in the past, I got the job. Plus, their recommendation to their friends who needed a mechanic always built business.Well, I guess that's the great thing about being me...I am my own mechanic. Figure I'm not going screw myself... I know not everybody has the want, desire, or aptitude to wrench themselves, but as long as the good Lord lets me, I'll turn wrenches myself...
I'm sorry you had bad experiences at dealerships. I've worked at both dealerships and independent shops before owning my own.W+B agreed!
There are some great mechanics out there. But most don't tend to work for stealerships. At an independant shop the mechanic can call the shots. In general at a dealership there is exactly 0% interface between the mechanic and the customer. In between is the service writer or adviser. Over the years I've found most of these folks to be liars and con artists with very little real knowledge of the mechanicals. It's their job to ligthen your wallet. I don't trust them. I could tell stories that would curl your hair.
+1!Automotive technicians are not mechanics by any stretch of the imagination. M-B techs working on smarts seem to be a level below most other techs.
Perhaps I should be more specific. Replacing a traditional shock absorber does not require an alignment. The words shocks and struts tend to be used interchangeably, but they are not the same design.Also just replacing shocks should have no affect on the alignment and getting it aligned should not be necessary if you are just replacing shocks and everything else is okay.
The service manual for some Mercedes say that a small leak in itself is not a reason to replace a shock.
