Side Skirts Removal and Reinstall Instruction
Anyone else care to chime in with side skirt installation instructions?
Although It's rather simple to remove, but most guys would get the install part wrong because it's not an identical reverse process.
Removal:
1. Remove the two plastic rivets in the rear wheel well with a flat head screw driver
2. Carefully pop the rear end of the skirt outward towards you
3. Slide the skirt towards the rear end of the car, the whole skirt should come off.
Installation:
1. You should see the Five white plastic clips on the car, unscrew them
2. Slide them into the side skirt, make sure they are facing the right direction and it will click if inserted properly.
3. Line up the skirt against the car, hook the front of skirt right next to the front wheel... check carefully all the white clips are lined up against the screws on the car, and just pop them back in.
4. Insert the plastic rivet back and you're done.
