I have replaced actuator, clutch ( since 150000) and the tcm was soak and wet. Know my issue is that it will go through all the gear after relearned but in a few mile it will skip 2nd gear all together. I took off the shifter motor cleaned both sides still no change. My question should get a used one or maybe get new brushes installed, any suggestions at a loss.
Sent from my SM-G892A using Tapatalk
Starting to sound like a trip to the dealer.
Before you do that... might want to check all the wires to the
shift actuator, gear shift motors, possibly do a battery disconnect
for an hour then reconnect. If its a gremlin in there running around,
better you find it first!
