Hello,
(Smart 450 fortwo - 1999 - gasoline)
My Smart car had a short due to water damage. The short was in de secondary fuse-boxe (F2) underneath the drivers seat.
After the repair, there was no communication with the MME (Meg motor electronics control unit/ECU)
("1 line on the speedo", a CAN bus fault )
After replacing the MME/ECU (and transfer the EEPROM) the CAN bus fault was gone.
But now:
The engine won't start. (Nor crank)
Car keeps beeping.
The following lights are on: Engine, Ale30 (Oil) & Charge indivator (battery).
The screen says "N". When turning the key, it flickers "0" and than goes to the "N".
I have a ICarsoft Multi-system Car Diagnostic Tool MB V2.0
I can see (and read) the following modules:
From the MME/ECU can i read the moduel info and data, but i can't read any faults nor delete them.
In the attachments: A readout with a ICarsoft of all the data it can see.
Has anyone an idea or tips?
Thanks in advance
Andries
But now:
Car keeps beeping.
- MME - Meg motor electronics control unit
- ABS - ABS control module
- RS - Restraint systems controller
- IC - Instrument cluster A1
- SZ - SAM-ZEE control unit
Thanks in advance
Andries
