Hello, I have smart 451 2007.
The door wont lock with the key but...The doors can be locked with dashboard buttons, key also can unlock trunk and the unlock function on the key also works(you can hear the clicks in doors). So the battery of the key is fine...its new key, the fuses on the SAM are also fine and when I try to lock it, it flashes two times.
The key was programmed 3 days ago...its not original its chinese, but I really dont understand where the problem could be. Also the key gives the same frequency for every function.
Is the sequence that key sends the problem, some relay on the SAM or something else?
Thank you in advance!
