Hi wanted to show a trailer I use. Works great.
Not true at all. I have a 4x8 trailer from HF that is rated for 1195 lbs. I've used this thing for literally everything. Many times I'm quite sure I've been overweight and it took it like a champ. Even had it loaded down with red clay, tires aired to the max(they were still squatting) and it worked great. I know that I've put at least 10k miles on it and no problem with the bearings failing or overheating. I check them after long drives. Here are a few pics of what I've done. Wish I had more to demonstrate.I wouldn't use a HF trailer as a pop-up platform without drastic modifications first. The wheel bearings and the tongue are weak spots on HF trailers and like to fail when towing a lot of weight.
I've had a HF 4X8 1195 lbs. Cap. for 4 years now haven't had a single problem towing it. I know I have overloaded at times too. It handled it well. The only thing I did extra when I assembled it was to hand pack the wheel bearings with syn. bearing grease. It has a few thousand miles on it now and other than needing new tires it's perfect.I wouldn't use a HF trailer as a pop-up platform without drastic modifications first. The wheel bearings and the tongue are weak spots on HF trailers and like to fail when towing a lot of weight.
Not true at all. I have a 4x8 trailer from HF that is rated for 1195 lbs. I've used this thing for literally everything. Many times I'm quite sure I've been overweight and it took it like a champ. Even had it loaded down with red clay, tires aired to the max(they were still squatting) and it worked great. I know that I've put at least 10k miles on it and no problem with the bearings failing or overheating. I check them after long drives. Here are a few pics of what I've done. Wish I had more to demonstrate.[/QUO
You live in the land of pickup trucks. I bet the good old boys, get a kick watching you haul everything, but the kitchen sink. Love the mattress photo. Yeeha!
Where did you find your receiver (hitch)? Brand? We just bought a 2017 and need to put one on it. Our other two smarts each have a curt hitch but curt doesn't seem to list one for the 2017. We have two trailers that we pull behind them. One is a tent camper.
Yea unfortunately no one makes a hitch for the 453... made this one in my brothers barn.
