Hello all,
So I'm using a smart ed transmission (A4513502400) for a project I'm putting together.. I picked the ed transmission (drive unit). As it seems as simple as it can get. Only moving part is the selector arm. And only one sensor, which I'm guessing is the position sensor.
I was told it is P R N D only.. so I tried running the transmission through those positions. Just like you would with most any other trans to check the operation...
I can only move the lever/selector onto two positions!?
Am I missing something here? P should lock it up. And the other position let's the diff turn in either direction when the the motor shaft is turned. I can't find R, N, or D.
I looked at the other post and most all those are questioning a park or stuck in gear issue. So I'm kinda lost....
Thx,
Kev
Thx,
Kev
