Hello to fellow Smarties,
I am new to the forum so please forgive me if this is posted incorrectly or if I offend anyone by my misunderstanding forum options.
I also want to thank everyone who posted their tow suggestions as they were very helpful in setting up mine.
Just returned from 1000+ mile trip towing the "Giggle Box" for the first time. No problems at all. I forgot to attach the bungee cord one day in the mountains. Did not suffer any apparent issues, but always used the bungee before and after that occasion.
I had read more than one problem with the "hood" access panel coming loose and being destroyed because owners routed the lighting wiring
inside and had to open and re-lock it to plug the wiring in each time. While the front body clip was off for the base plate install, I mounted the wiring plug just below the license plate and ran the wire harness up to the fire wall and through into the cabin. See pics
I had bad experiences using the tow vehicle lights and wiring in our former tow-a Jeep. So, I bypassed the Smart wiring and made some easy brackets with LED trailer lights. Worked out very well and the lights are nice and bright. I used some metal mending plates from Home Depot and bent them 90 degrees. Then, slotted them with a dremmel for easy mount/dismount on Smartie. Just two screws on each side panel where the rear "trunk" seam is. Also, optional quick connects on wiring to store the lights at home. See pics
I installed a Roadmaster base plate. Did it myself- not easy, but quite doable if you have any automotive mechanical experience. Most trouble was removing and re-installing the sills, or rocker panels. They hide a single screw which needs to be removed to take off the front body clip. For anyone doing their own baseplate install I do have a simple modification to the instructions which strengthens the attachment to the Smart frame ends- well worthwhile. It sounds formidable, but removing the front body clip itself was quite easy.
By the way, love driving the "Giggle Box" So much fun. Surprising the attention it draws at campgrounds.
