1 - 1 of 1 Posts
Administrator
Here you will find prices for the Smart car models, including option packages. These prices do not include any tax, freight, PDI (Pre-Delivery and Inspection) or any additional dealer charges. If you wanted to purchase a Smart car without delay, you can! One method is a secondary market place that has started up on eBay. The other method is buying an “orphan.”
An orphan Smart car is one that has been prepped for sale but, for some reason, the buyer did not complete the transaction.
It's a straightforward process. You can start by submitting your request and information to all the smart USA dealers. E-mail or, better yet, phone them and tell them you are a buyer, not merely a tire kicker. If the dealer says yes, ask how you can send your deposit and when you can take delivery. Some dealers may be impartial in their allocation of the cars and you may get lucky. In some cases, simply put, it may be a first-come, first-served deal?
Prices Smart Pure - $11,590
Option Prices in $USD
- A/C w/ Auto temp control $600 Metallic Paint (R, B, S) $225
- Silver colored Tridion cell $175 Alarm $160
- Panorama roof – Sun shade incl. $350 Power Steering $450
- Heated Seats $220 Radio - AM/FM/CD $350
- Premium radio - AM/FM/6CD/MP3 $495
Smart Passion - $13,590
- A/C w/ Auto temp control STANDARD
- Panorama roof – Sun shade incl. STANDARD
- Radio - AM/FM/CD STANDARD
- Metallic Paint (R, B, S) $225 Silver colored Tridion cell $175
- Alarm $160 Power Steering $450
- Heated Seats $220 Fog Lamps $110
- Additional instruments – Analog Clock and Tach $120
- Premium radio - AM/FM/6CD/MP3 $150
Option packages:
Premium Sound $350 includes Premium Radio w/ 4 speakers and Sub. Comfort Package - $850 - Includes Power Steering, Leather Seats, Heated Seats, Rain and Light Sensor and Auto-off headlights w/ exit delay.
Smart Passion Cabriolet - $16,590
Option packages:
Engineering:
- Engine Type: In-Line 3-Cylinder
- Engine Block/Cylinder Head: Aluminum-Alloy
- Displacement (l): 1.0
- Horsepower @ rpm (SAE net, Rev 8/04): 70 HP @ 5,800 rpm
- Torque (lb.-ft. @ rpm): 68 lb.-ft. @ 4,500 rpm
- Redline (rpm): TBD
- Bore and Stroke (in): 2.83 x 3.22
- Compression Ratio: 10.0:1
- Valve train: 4-valve per cyl. - SOHC
- Electronic Multi-Point Fuel Injection
- Rear-wheel Drive
- CARB Emissions Rating: ULEV-2
- Federal Emissions: Tier II/Bin5
- Direct Ignition System with Immobilizer
Transmissions: 5-Speed Automated Manual
Gear Ratios: 1st: 3.308 2nd: 1.913 3rd: 1.258 4th: 0.943 5th: 0.707 Final Drive: 4.529 Reverse: 3.231
Body/Suspension/Chassis: Unit-Body Construction MacPherson Strut Front Suspension DeDion axle Rear Suspension Stabilizer Bar (mm, front): TBD mm/none
Rack-and-Pinion Steering: Turning Diameter, Curb-to-Curb (ft.): 28.7
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11/8 Wheels: All-Season Tires: 155/60 R15 Front/175/55 R15 Rear
Interior Measurements:
- Headroom (in.): 39.7
- Legroom (in.): 41.2
- Shoulder Room (in.): 48
- Hip-room (in.): 45.4
- Cargo Volume (cu. ft.): 12.0
- Passenger Volume (cu. ft.): 45.4
- Seating Capacity: 2
Exterior Measurements:
- Wheelbase (in.): 73.5
- Length (in.): 106.1
- Height (in.): 60.71
- Width (in.): 61.38
- Track (in., front/rear): 50.51/54.53
- Coefficient of Drag: 0.34
- Curb Weight (lbs.): 1,808
08 EPA Mileages:
- 5-Speed Automatic Manual (City/Highway): 34/40
- Crankcase (qt.): 3.5 incl. oil filter
- Required Fuel: Premium Unleaded recommended
- Coolant System (qt.): 4.5.
- Fuel Tank: 10 gallon – 8.7 with 1.3 gal. Reserve
1 - 1 of 1 Posts
