People also ask
What does a shifter cable do?
How do you know if your shifter cable is bad?
Symptoms of a Bad or Failing Shift Selector Cable
Symptoms of a Bad or Failing Shift Selector Cable | YourMechanic
- Indicator doesn't match the gear. If the shift selector cable is going bad, the indicator light or cable will not match the gear you are in. ...
- Vehicle will not turn off. ...
- Vehicle starts in another gear. ...
- Vehicle will not go into gear.
