1 - 12 of 12 Posts
Smart Fortwo Turn Signal Bulbs
From the factory, turn signal bulbs are powered by standard incandescent lights that light up amber in color.
Newer luxury vehicles are using LEDs for turn signals, because LEDs offer a crisp, instant on/off, increased brightness, and true, vibrant color. By replacing the bulbs in your Fortwo, you can achieve this modern look!
Resistor Option: The Smart Fortwo will hyperflash when LED bulbs are installed as turn signal replacements. We offer a resistor kit option to remedy this issue
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness:
HP48: (280 lumens) Similar brightness to OEM bulbs
HP11: (310 lumens) Slightly higher brightness than OEM bulbs.
XP80: (510 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
Front Turn Signal LEDs for 2010-2015+ Smart Fortwo
Any questions, feel free to ask via email ([email protected]), Post or shoot us a PM!
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
If the lights need resistors to work properly, why not include them in the price?
They will still function correctly without resistors, but you'll get hyperflash with the turn signal locations. Some customers actually prefer hyperflash, so we give them the option to purchase the resistor kit.
Nick C.
1 - 12 of 12 Posts
