Hey guys! I recently Purchased Smart Madness Auto Flash and Go Pedal. The auto flash was as simple as it got to installation, however as far as the go pedal.. After removing the accelerator pedal sensor and connecting it.. Nada. No lights on start up, and the accelerator wouldn't even give me any gas. Had to switch it back to stock for it to work :\. Any idea what could be going wrong?
We’re the plugs seated correctly? Mine came loose after first test drive and I was “dead in the water” until I went down there and made sure all plugs were clicking together completely.
· 10Year+ Supporting Member
2009 Brabus Coupe
I agree with the above post. You will hear an audible click when the two plugs are properly snapped in place. There is not a lot of working room for large hands, so take your time and use a bright light to help see what you are doing.
· Vendor
First I'd like to thank you for purchasing our Autoflash and GOPedal.
There are clips on each of the plugs that secure them in place. You should hear each one click when you press it into place and they should be nearly impossible to remove without unclipping them. If that does not fix the issue please give us a call and one of our team members will help diagnose the issue.
888-993-7552
